Hi
I have archlinux with kernel 5.6.8-arch1-1 and Audacity 2.3.3 installed from distribution's release.
After install and activate pulseaudio because the mic didn't work I tried to open a little .amr I recorded before on my phone then Audacity crashed.
I attach the report files:
(I deleted my RecentFiles).
Thanks in advance.
Crashes when open an .amr file
Please state:
Please state:
Re: Crashes when open an .amr file
How big is that file? Do you still have it?
Look in "Edit menu > Preferences > Libraries"
Does Audacity have FFmpeg installed?
