Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
waxcylinder
Post
by waxcylinder » Thu May 07, 2020 9:56 am
юра00 wrote: ↑Thu May 07, 2020 1:33 am
Zoom max. And why not? Before everything was fine with any zoom level. "Windows" key action: it turns out ever in previous version:
Ahhhh, now I realize what's happening - this was a deliberate change we made in 2.4.0 to fix this bug and arises as a consequence of that:
https://bugzilla.audacityteam.org/show_bug.cgi?id=2389
At some zoom levels the light-blue/white selection visual cue disappears
So what you are seeing is a cursor that is positioned between samples (the black line) and the actual audacity point "selection" made with the cursor i.e. the nearest sample (only samples can be selected - not the space between them). This is the light colored line through the nearest, the selected, sample.
Peter.
waxcylinder
Post
by waxcylinder » Thu May 07, 2020 9:57 am
юра00 wrote: ↑Thu May 07, 2020 1:43 am
When you press Windows key - a window "left selection boundary" appears.
I cannot reproduce this with RC05
Peter
- Site Admin
Post
by steve » Thu May 07, 2020 10:49 am
@юра00 I'm guessing that you are not testing a clean installation.
Try resetting Audacity Preferences, or set up a Portable Settings folder for RC05 to use.
waxcylinder
Post
by waxcylinder » Thu May 07, 2020 11:59 am
waxcylinder wrote: ↑Thu May 07, 2020 9:56 am
If you really must work at such close zoomed in levels and you don't want to see the double lines:
1) set the time format in the Selection toolbar to hh:mm:ss + samples
2) set Snap To (in the Selection toolbar) to be on
Peter.
