NO VOLUME
TJB
NO VOLUME
Post by TJB » Mon May 04, 2020 3:37 pm
EVERYTHING WAS WORKING FINE UNTIL TODAY. NOW WHEN I RECORD, THE SOUND VOLUME IS SO LOW THAT IT'S UNUSABLE.
TO RECORD ANYTHING, I HAVE TO YELL INTO THE MIC .... WHEN I ATTEMPT TO RECORD (WITHOUT YELLING), THE RECORDING METER TOOLBAR ONLY RECORDS SOUNDS IN THE SUPER QUIET RANGE OF -57 TO -51 ... AND IT'S SO LOW THAT IT BARELY SHOWS UP ON THE GRAPHIC SOUND TRACK.
HELP, PLS ................. I'M STUCK
Re: NO VOLUME
Post by steve » Mon May 04, 2020 4:03 pm
Please avoid typing in all upper case.
What sort of microphone are you using?
How is the microphone connected to your computer?
Which version of Audacity?
What settings do you have in the Device Toolbar?
Do you use Skype or other conferencing type software?
Are you sure that Audacity is recording from your microphone and not the laptop's built in mic?
TJB
Re: NO VOLUME
Post by TJB » Mon May 04, 2020 4:17 pm
Mic is an MXL BCD-1 dynamic
I use a ProFX6v3 mixer
Mic is connected from the mixer to the computer with USB cable
Using Audacity 2.3.3
Device toolbar shows: MME Line Pro FX 1 (mono) Speakers High Def Audio
No as to Skype
Some further info ... I just yelled into the mic and it barely registered ... RSM measured -61
Re: NO VOLUME
Post by steve » Mon May 04, 2020 4:21 pm
How much level are you seeing on the mixer's meter?
Re: NO VOLUME
Post by kozikowski » Mon May 04, 2020 4:24 pm
Do you sound OK when you listen with headphones plugged into the mixer? Do your mixer flashing volume lights light up to at least "0"?
TJB
Re: NO VOLUME
Post by TJB » Mon May 04, 2020 4:29 pm
Scle reads fro toop to bottom:
14
8
4
0
4 ....................... and it's registering from 4 down to 24
12
24
TJB
Re: NO VOLUME
Post by TJB » Mon May 04, 2020 4:32 pm
Koz, my guru ... yes, headphones sound OK
TJB
Re: NO VOLUME
Post by TJB » Mon May 04, 2020 5:07 pm
I've also checked all cable connections and rebooted the computer as well.
Like I said earlier, if I yell into the computer it will register SLIGHTLY on the track and when I ran a RSM check on that section, it showed RSM at -61
TJB
Re: NO VOLUME
Post by TJB » Tue May 05, 2020 8:50 pm
Still having same problem. When I record, it's barely visible on the sound track ... and I mean barely !!! Makes it difficult to use.
On the Recording Tool Bar it only hits on 54 to 48 ... even if I yell into it.
But i was able to record a chapter, then did the Mastering (filter curve, RMS Normalize, Limiter and Hum removal) with the following results:
Peak 3.5 Passed ACX
RMS 20.6 Passed
Noise -58,5 Failed
Then applied Noise Reduction with following results:
Peak 3.3 Passed
RMS 20.8 Passed
Noise 66.5 Passed
I think what concerns me is that just two days ago, following the same scenario above, my noise level was in mid to low 70's and I have a hunch that this difference is somehow related to lack of volume DURING the recording.
Any thoughts or suggestions ???
