Please help me! Thanks
Crossfade clips
Crossfade clips
Hi, i have just installed the latest Audacity version 2.3.3, but now in all of my projects, and even in new projects it seems to be impossible to crossfade clips. I get this message (attached) (translated: invalid selection, more than two audioclips selected)
- Attachments
- Schermafbeelding 2020-05-01 om 14.49.15.png (52.01 KiB) Viewed 138 times
Re: Crossfade clips
Can somebody PLEASE help me out?
Re: Crossfade clips
I've never tried a "crossfade effect", but I've made manual crossfades.
Re: Crossfade clips
Please don't double post. I have replied here: viewtopic.php?p=393823#p393823
I'll close this topic to avoid confusion.
