Mac:(13-inch, 2017, Two Thunderbolt 3 ports)
Audacity: 2.3.3
Mic: Samson Meteor Mic (USB, condensor) http://www.samsontech.com/samson/produc ... meteormic/
Hi
My Problem: There is a high background noise on every audio recording I'm doing EVEN THOUGH IT IS COMPLETELY QUIET IN THE ROOM. (listen to file in attachment, maybe crank up your volume) What causes this background noise? Is there a way to make sure it won't be recorded? (I know there are ways to filter it out afterwords with audacity, but I would love not to have that noise in the first place as I am planning on recording many many audios)
What I have tried so far and hasn't had any impact:
-using different usb 3.0 Adapter ports
-downloading the mic-specific software: Samson Sound Deck -> there is an option that sais "digital noise reduction" but it doesn't make any difference whether it is checkd on or off (unless I am too stupid to turn it on correctly -> see screenshot)
-detaching power cable of mac
-Background noise doesn't seem to depend on recording software: Same background noise if audacity or Quicktime is used.
Can anyone help me with this? If you need more specifics pls let me know and I am more than happy to help!
Thanks a lot already
Best,
Chris
