left and right channels not in synch
davethewave
I have a rec that I think must not be in synch because it is very reverbish and echoed.Any way to correct?
Re: left and right channels not in synch
That's hard to believe... Have you tried listening to the left & right separately?left and right channels not in synch
What are you recording and how are you connected, etc? Are you recording from the microphone built-into your laptop? Streaming audio from the Internet? A USB turntable? etc.?
Depending on how you asked that, no, you can't fix that kind of distortion with filters or effects.Any way to correct?
