Audio from UTube
braxx20
Audio from UTube
Post by braxx20 » Sun Apr 26, 2020 7:24 pm
Can one get a high quality recording from U Tube? Sometimes I think that they are degrading the audio.
Re: Audio from UTube
Post by steve » Sun Apr 26, 2020 8:31 pm
I presume that you mean YouTube?
The audio on YouTube is not very high quality, but it should be possible to record at close to the same quality as it sounds when playing a video on YouTube. If the recording quality is noticeably worse than playing the video, then there is probably something wrong with your recording setup. A common mistake that leads to poor quality is accidentally recording from a laptop's microphone instead of directly recording the audio stream.
Trebor
Post by Trebor » Sun Apr 26, 2020 8:36 pm
YouTube audio depends on the quality selected for playback,
see ... https://youtu.be/g2xb9fjvcyc
braxx20
Post by braxx20 » Thu Apr 30, 2020 7:08 pm
Thanks but I am interested in AUDIO not VIDEO. Are there settings in Audacity that would be optimal for recording music from You tube?
Post by steve » Thu Apr 30, 2020 8:26 pm
The playback quality settings in YouTube affect both video and audio. At low kbps settings, both the video and audio quality will be poor. Higher kbps settings can support better quality video and better quality audio.
The default quality settings in Audacity are suitable for high quality recording from any source, YouTube or any other.
braxx20
Post by braxx20 » Fri May 01, 2020 1:17 am
Good, THANKS!
