Make labels from data
Please state:
Please state:
Aoa i have project using ubuntu to capture data then make labels on audacity double talk,single talk each file should have sample size 1024 i dont understand how i set it on audacity....
Reason: Topic split and given relevant title
Re: Make labels from data
What does that mean
What sort of data?
How are you capturing it?
What does that mean? Are you referring to "mono" and "stereo" tracks?
I don't understand what your question is.
