Editing Audacity 2.3.3
Please state:
boolsifter
Re: Editing Audacity 2.3.3
Post by boolsifter » Mon Apr 27, 2020 10:30 am
Sorry that was only a typo, instead of typing exp(6) like I thought I did, I had typed exp(8) which is not an odd harmonic. I do use the square wave generator in tone and chirp.. Phil
