SOLVED Reverb silences the audio
Jebbers
Operating System: Linux Mint
Post by Jebbers » Sat Apr 25, 2020 6:18 pm
Hey! I've never had a problem with reverb before. I'm using a standard preset. no matter how I set the effect, the preview sound fine, but when I add the effect the result is a flat line, as if I had used ctrl+L.
SOLVED: Turns out I had two tracks selected at once. So that effect does not work except on one single track. Just thought I'd post this, in case anyone else should have a problem and go searching for "reverb silence."
Re: SOLVED Reverb silences the audio
Post by steve » Sat Apr 25, 2020 9:26 pm
Oh dear. That's a bug. It "should" work on multiple tracks, but that appears to have broken at some point.
I'll log it on the bug tracker.
Jebbers
Post by Jebbers » Sun Apr 26, 2020 5:37 pm
Post by steve » Sun Apr 26, 2020 5:44 pm
The surprising thing is that the bug appears to have been present for over a year, and you're the first to mention it! :shock:
Jebbers
Post by Jebbers » Sun Apr 26, 2020 5:49 pm
I think we usually apply effects to one track at a time.
waxcylinder
Post by waxcylinder » Mon Apr 27, 2020 9:33 am
Good catch Jebbers 8-)
Peter
