Saving just the audio from MP4 and saving to MP3
auralsex
Post by auralsex » Fri Apr 24, 2020 6:27 pm
can this be accomplished in Audacity? I hope to make a much smaller MP3 file.
DVDdoug
Forum Crew
Re: Saving just the audio from MP4 and saving to MP3
Post by DVDdoug » Fri Apr 24, 2020 6:39 pm
Yes, but you'll need to install the FFmpeg import/export library. (Download and run ffmpeg-win-2.2.2.exe.)
When you open the file with Audacity, you'll get the audio-only. Then you can export as MP3 or WAV, etc.
Note that when you open a compressed file in Audacity (or any "normal" audio editor) it gets decompressed. If you then re-export to MP3 (or other lossy format) you are going through another generation of lossy compression. You may not hear any quality loss, and you may not have a choice, but it's something you should be aware of.
auralsex
Post by auralsex » Fri Apr 24, 2020 7:59 pm
thanks, this will be a nice time saver. And I will still have the option to save in bitrates that will suit my needs? For a simple spoken word performance
what setting should I look towards if I want the smallest file possible and still acceptable quality. And yes , original file quality will be the most important factor.
DVDdoug
Forum Crew
Post by DVDdoug » Fri Apr 24, 2020 9:27 pm
Yes, when you select File -> Export -> Export As MP3 you'll see the various bitrate/quality settings.
