None of the judges turned their chairs
Help for Audacity on macOS.
kmarler
Post by kmarler » Thu Apr 23, 2020 6:41 am
Hey folks,
I've been rejected by Bunny Studio. (Words I never thought I'd hear myself say)
They said issues were ...
1.) Compression- Your recording is heavily compressed and/or limited. It\'s affecting the dynamics and quality of the audio. Instead, please raise the volume via automation or normalization to -3dBFS peak.
2.) Hiss/White noise- There is a high level of white noise/hiss impacting your recording that is adversely affecting the quality of the deliverable.
So here's my situation (sorry, going to be long). I'm using Audacity 2.3.3 (Mac High Sierra 10.13.6) and running it through my Boss Acoustic VE-8 Pre-Amp into an AKG-C214 condenser mic. I did the whole recommended Macro chain (limiter, filter curve, RMS Normalize) and ACX check thing and it passes with flying colors, but the problem is that when you apply the RMS Normalize thing it blows up the gain and then condenses it down with the limiter which I think is what they're dinging me for when they say it's "heavily compressed".
Then, of course, since the RMS Normalize thing is on it's boosting my gain and making my background noise come through making the hiss sound they mention. If I try to hit it with the Noise Reduction of the beast I then often fall out of the sweet spot of -23 to -18 RMS and get too quiet. It's kind of a damned if I do you damned if I don't type thing.
One part of me maybe thinks it's my pre amp just because I don't know anyone who uses the VE-8 as a pre amp and I've got it cranked to max on the volume, but it's like a $400 pre-amp so I'd hate to think it's not top notch enough. The mic is also $400 so then again maybe I'm thinking it's just my lack of audio engineering expertise.
Bunny Studio sent me this hour long video on what could make a hiss and after watching it and troubleshooting I'm pretty sure it wasn't anything external like appliances or cables or anything.
Anyways, I've got two tracks to share with you guys at the link on the bottom of the post here. The first, is the original track I sent to the Bunny people that got denied and the second is one that I hit with noise reduction and somehow got it to stay between -23 and -18 RMS but not hit the peak -3.5 range so I'm hoping the second take could be good enough for a re-submission. My concern is just that on many other samples I've recorded I don't get so lucky with simply hitting it with the noise reduction and fixing it (it gets too quiet overall and falls out of the -23 and -18 range and fails the ACX check); however, it still may not be fixed. I'll let you guys be the judge of that.
https://drive.google.com/drive/folders/ ... sp=sharing
Re: None of the judges turned their chairs
Post by kozikowski » Thu Apr 23, 2020 9:20 am
The Audiobook Mastering Suite doesn't use compressors.
RMS Normalize is a straight, plain volume control with a fancy name. The suite was designed to hit audiobook RMS (Loudness) and Peak numbers without creating its own sound personality or compression distortion. Most of the time it just makes the voice louder (home systems tend to quiet recording).
However, your pedal has a lot of theater effects and I suspect that's what Bunny Studio didn't like.
If I assume Bunny works like Audible/ACX in the US. Their model is someone telling you a story over cups of coffee in real life, not announcing a story in a club.
Post a voice sample on the forum. It doesn't have to be English, but we do need that two seconds of clean room sound at the beginning.
https://www.kozco.com/tech/audacity/Tes ... _Clip.html
Post by kozikowski » Thu Apr 23, 2020 9:39 am
Nothing wrong with the microphone.
It's side-fire, or side address, so you should be speaking into the company name. It doesn't matter if the microphone is upside down.
You should be about a Hawaiian Shaka away.
The microphone has two switches, The 0dB/-20dB switch should be on 0dB (louder). The low pitch rolloff (straight line/bent line) should be off—straight line. There is a low pitch rolloff built into the Mastering Suite.
kmarler
Post by kmarler » Tue Apr 28, 2020 6:05 am
Koz,
Thank you so much for your help !
I've attached two files. In the first one, titled "Audacity Shaka Sample", I'm standing about a shaka shake away from the mic. My peak dBFS reading was -13.5 and it just sounded super quiet to me so I also made a second recording titled, "Audacity closer sample', where I was probably 50% closer and got a -10 dBFS peak reading.
To address some of the other points you raised :
1. When you use the term "Audiobook Mastering Suite" are you referring to the Macro that Audacity suggests you create for ACX work (filter curve, RMS Normalizer, Limiter) ?
2. So RMS Normalization doesn't compress ? And neither does the ACX Macro I described in point #1 ? I just want to be crystal clear on that. P.S. I posted on the Bunny forum to try to understand from their end where my recordings are going wrong and they voiced criticism of RMS Normalization though I'm not sure why. You can check it out if you want to and perhaps offer some clarity of their distaste. I'm not trying to start a war I just want to get to the bottom of this whole recording process. (viewtopic.php?f=47&t=110396).
3. The Bunny people said they would do more research on my pedal cuz they've never had anyone use it. Although it has a ton of effects as you mentioned none of them are engaged when I'm recording voice overs so I feel like it shouldn't matter; however, perhaps it still makes a difference. I obviously don't know.
4. In your second post about 10 minutes later where you provided a picture of the shaka example you said, "it's a side fire". Did you mean that I wasn't talking directly into the mic on the first recording I sent and you could hear that ? (I tried to be mindful of that for the attached recordings.)
5. I had the db switch to the louder setting but I had the low pitch rolloff set to the curved line so I switched that for the attached recordings as well.
Again, you mention the "mastering suite" in the end of that last post. I'm just wondering if that is only enabled when you apply the ACX Macro or if you mean that is automatically applied whenever you record anything into Audacity?
Thanks again man. By the way, did you develop this program or something ? How do you know so much ?
Kyle
audacity shaka sample.wav
(861.03 KiB) Downloaded 3 times
audacity closer sample.wav
(862.06 KiB) Downloaded 3 times
Post by kozikowski » Tue Apr 28, 2020 9:32 am
ACX Macro
I would probably stop calling it that. Making a Macro out of the three mastering tools has problems because Effect > Filter Curve does not always call the right curve when you use it in a Macro. If you used Effect > Filter Curve in production between audiobook readings, you may or may not get "Low Rolloff" inside a macro—and there's no good way to know there's a mistake other than using complicated analysis tools.
Low Rolloff is an important part of the mastering process and leaving it out or calling a different curve can cause very serious problems.
This is the Audiobook Mastering Suite.
At least until the next Audacity version, you should use the three tools just like that. The settings are sticky, so you only have to set up the tools once and then use them rapidly forever—again, unless you did a lot of production between the audiobook readings. I can get through mastering in about 20 seconds or less.
That's probably OK. Audiobook Mastering guarantees ACX Peak and RMS (Loudness) from whatever you read and the only limit after that is noise. If you fail noise, that's when troubleshooting can get more interesting.
I'm going for your sound samples.
Post by kozikowski » Tue Apr 28, 2020 10:28 am
I don't hear any compression or processing.
I mastered Shaka and it easily passes ACX Audiobook standards. First three readings and sentence 2/3 down. The Noise Limit is -60dB, you should pass that by at least -65dB, and yours is -68dB.
audacity_shaka_sample-Mastered.wav
(767.57 KiB) Downloaded 1 time
The only difference I can find is a "warmer, more intimate" sound on the closer file. The flip side of that is your Shaka file sounds clearer and cleaner. That's normal. That's proximity effect on directional microphones. I once played two different characters by using that effect.
I'm not a developer. I've just been doing sound for a long time. Many sound programs have a lot of the same tools and it's just getting used to this one.
"Let's see. Where did they put the Equalizer. Oh, it's called 'Filter Curve' now."
Post by kozikowski » Tue Apr 28, 2020 10:38 am
One other note. Your chapters have to match, so if you go for the warm, comfortable sound with a single character or narrator, you have to do it that way through the whole book.
Another New User problem. The first and last chapters also have to match.
Post by kozikowski » Tue Apr 28, 2020 10:45 am
1.) Compression- Your recording is heavily compressed...
2.) Hiss/White noise- There is a high level of white noise/hiss...
A lot of production is bookkeeping. Are you absolutely sure you sent Bunny Studio a clean sample? Their reaction and your sound files don't match.
Did they call your submission file by name? What's the possibility they're listening to the wrong file? With the virus lockdowns, everybody with a pulse is trying to read for audiobooks and the production companies are overloaded. ACX actually says so in their submission documents.
kmarler
Post by kmarler » Tue Apr 28, 2020 7:33 pm
Koz,
Once again, thank you for your time and all of this feedback.
I have been using the Effects within a Macro so I'll stop doing that and apply them individually.
I don't think it's likely the Bunny people are listening to the wrong track because I've actually auditioned for them twice now and rejected me both times.
Like I said, I'm in communication with them on another forum now, so hopefully they are able to shed light, but I appreciate your help.
Perhaps, as you said, the competition is just super fierce and I'm not making the cut.
Thanks,
Kyle Marler
Post by kozikowski » Tue Apr 28, 2020 11:32 pm
Does Bunny have a posted list of standards and practices? Audacity Audiobook Mastering is based on the published notes of ACX/Audible, and we have had multiple successes from performers who follow all the rules.
There are two side trips. If Bunny falls in love with digital zero background noise, that's valid (for them) but it's much harder to master and still have your voice sound natural. That's the "talking over the blackness of space" sound.
We can't prove this, but it's possible both companies complain about technical problems when they just don't like your announcing style and it's rough to specifically complain about that. "Your voice makes my ears hurt" is hard, but I can see needing to deal with that in some conditions.
There was one performer who had clinical asthma and they were profoundly uncomfortable to listen to. We got their submission up to technical standards and no further word how the book went.
You do have one thing going for you. ACX will not interact with you. At all. 'You failed because of the following problems, here are some helpful web pages, have a happy day.'
Full Stop.
