Combine 2 seperate projects
davethewave
As I have changed over to Windows 7, this question is for an XP computer. I need to add A 1 hour show to A 3 hour show.I made space available in front of the 3 hour by creating silence. I have tried copy / paste but that don't work.Thanx for your help.
Re: Combine 2 seperate projects
Are the "shows" audio files, or Audacity Projects?
