How to troubleshoot recording stops after five minutes
Please state:
LNordin
Post by LNordin » Wed Apr 22, 2020 9:56 pm
I have a problem where audacity will stop recording after 5 or 6 minutes.
I've read through the FAQ but haven't seen anything that applies to me.
The directory configured for temporary files has 7 GB of available space.
Is there a log to see what error occurred that stopped the recording?
I looked in Help > Diagnostics > Show Log but this doesn't have any errors.
I'm running Kubuntu 18.04.4 and Audacity v2.2.1.
Re: How to troubleshoot recording stops after five minutes
Post by steve » Wed Apr 22, 2020 11:24 pm
What is your recording device?
LNordin
Post by LNordin » Thu Apr 23, 2020 10:42 am
It is audio line in on a Dell PC. My choices are "default", "pulse" or "HDA Intel PCH: ALC3220 Analog (hw: 1,0)". My only choice for audio host is ALSA.
I just tried specifying HDA Intel but when I try to record most of the time it doesn't start.
I did notice that when I went to change the volume on KDE mixer that the recording stopped.
To fill in more standard information, I installed Ubuntu's version of Audacity.
Post by steve » Thu Apr 23, 2020 11:38 am
Is there no "(hw: 0,0)" option?
If you shut down all audio applications,
then kill the KDE mixer,
then run:
Code: Select all
pulseaudio -k
and then start Audacity,
do you get a "(hw: 0,0)" option?
LNordin
Post by LNordin » Thu Apr 23, 2020 7:30 pm
No, there is no "(hw: 0,0)" option
Couldn't find a kmix process to kill.
Tried killing pulseaudio (pulseaudio -k) but it kept restarting.
Post by steve » Thu Apr 23, 2020 8:15 pm
What do you get from the command
Code: Select all
aplay -l
(that's a lower case "L" at the end)
LNordin
Post by LNordin » Fri Apr 24, 2020 11:50 am
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: HDMI [HDA Intel HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: HDMI [HDA Intel HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 0: ALC3220 Analog [ALC3220 Analog]
Subdevices: 0/1
Post by steve » Fri Apr 24, 2020 1:19 pm
From your "aplay -l"
Code: Select all
card 0: HDMI ...
card 1: PCH
Your default device is the HDMI device. Do you use HDMI audio? Do you use HDMI audio as your default audio out?
Have you customised your audio system in some way?
LNordin
Post by LNordin » Sat Apr 25, 2020 10:11 pm
aplay -l
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
LNordin
Post by LNordin » Sun Apr 26, 2020 12:59 pm
I don't use HDMI audio. The only connection is the analog line out (on of the back the PC) out to speakers and analog mic in (on the front of the PC).
My monitor connection is currently VGA but otherwise I use DisplayPort (which I think is video only).
No. I don't think so. How can I tell?
