WORK FLOW
TJB
WORK FLOW
Post by TJB » Thu Apr 16, 2020 1:32 pm
ONCE I'VE FINISHED A RECORDING, I GO TO THE 'EFFECTS' AND APPLY:
NOISE REDUCTION
NORMALIZE
EQ
COMPRESSOR
NORMALIZE
SINCE I'M NEW AT THIS PROCESS, ARE THERE ANY OTHER EFFECTS THAT I SHOULD ROUTINELY BE USING?
Re: WORK FLOW
Post by steve » Sun Apr 19, 2020 11:11 am
Personally I don't "routinely" use any effects. I just use the effects that are appropriate for the specific thing that I'm doing.
