Automatic Gain Control on Recording? (Autosave?)
⚠️IMPORTANT
Operating System: Windows 7
Post by ⚠️IMPORTANT » Wed Apr 15, 2020 10:52 am
Hi
I have a huge problem I record Audio on Amateur Radio and some people scream in there Radio and some whisper so our Software often record to loud or nothing who is hearable. :shock:
Is there a way to Auto Save after 60Minutes + when its silent to not cutoff any Radio Call?
Thanks!
Re: Automatic Gain Control on Recording? (Autosave?)
Post by kozikowski » Wed Apr 15, 2020 1:45 pm
Audacity doesn't apply effects, filters or corrections when recording.
I don't know of a way to auto save, but Audacity has Sound Activated Recording. Audacity > Edit > Preferences > Recording > Sound Activated Recording.
Audacity doesn't make a very good surveillance recorder.
⚠️IMPORTANT
Post by ⚠️IMPORTANT » Wed Apr 15, 2020 2:02 pm
I use that currently. The problem is when it run 24/7 the file would get insane big and is not good to rehear if something happened back then. :? So smaler bits with a Time and Date would help a lot to find a incident.
Post by kozikowski » Wed Apr 15, 2020 5:27 pm
Yes it would.
Audacity doesn't have time stamps and it doesn't have progressive updating of storage files. That's a surveillance recorder.
Emerogork
Post by Emerogork » Thu Apr 16, 2020 6:52 am
I too would like an AGC when recording but I doubt it is worth my while to hold bu breath. (-:
If there is any way to help to move this along, count me in.
Right now I am looking into building one in Windows.
Post by steve » Thu Apr 16, 2020 1:32 pm
This is always a problem when working with amateurs. It makes editing a lengthy and painful process. The real solution is "don't work with amateurs unless they are willing to learn". Failing that, ensure that everything is recorded at a low enough volume to avoid clipping, and expect to do a lot of editing. Unfortunately there is no magic bullet.
Plug-ins such as "LevelSpeech2.NY" (viewtopic.php?p=337845#p337845) and "AGC" (viewtopic.php?p=194179#p194179) can help in some cases.
Note that Windows often provides automatic gain control in the "Sound Enhancements". We generally recommend turning that off as AGC is killer of high quality recording.
Another alternative is to record with a portable recorder. There are many models available, and they frequently have features like AGC and voice activation. As with computer recording, for high quality recording, it is usually best to switch those features off and use manual editing and compressors in post production.
⚠️IMPORTANT
Post by ⚠️IMPORTANT » Thu Apr 16, 2020 1:40 pm
I use an SDR and a Virtual Audio Cable.
