Recording sound being played on Computer
Blueflame
Post by Blueflame » Tue Apr 14, 2020 4:23 pm
Windows 10 Pro audacity 14.1
Some time ago I recorded some sound that was being played by the computer on audacity just by pressing the record button, this does not happen now.
Or do you have to do it a different way
Blueflame
DVDdoug
Forum Crew
Re: Recording sound being played on Computer
Post by DVDdoug » Tue Apr 14, 2020 4:48 pm
Use WASAPI (loopback) as your recording device.
Blueflame
Post by Blueflame » Wed Apr 15, 2020 9:10 am
Thanks I try it
Blueflame
