Volume surges after compression (audiobook recording)
Trebor
Re: Volume surges after compression (audiobook recording)
Post by Trebor » Fri Aug 21, 2020 9:21 am
I just noticed your mic has a bass-roll off switch.
If you switch that on it will reduce the excessive bassiness.
Abdiel
Post by Abdiel » Fri Aug 21, 2020 11:20 am
Ah, so that's what it's called. I'll experiment with that for the next book. Thank you for the link.
