Exporting parts of A recording (Solved)
davethewave
Post by davethewave » Tue Apr 07, 2020 11:47 pm
I'm having trouble moving a section of my latest recording. I put in the correct numbers in the start and end of selection boxes yet it starts at the beginning of the recording.Can't understand why it's doing this all of the sudden!
davethewave
Re: Exporting parts of A recording [SOLVED]
Post by davethewave » Tue Apr 07, 2020 11:54 pm
I found the problem. I wasn't using the "export SELECTED audio" tab
Reason: closed as "solved"
