USB Mic not detected
Help for Audacity on macOS.
matz2018
Post by matz2018 » Wed Apr 01, 2020 7:13 am
Hi. I am on Mac 10.14.6 with Audacity 2.3.3. I had a problem with the USB mic not being detected in a previous version of Audacity. So I downloaded 2.3.3 and it worked fine. It detected the USB mic. Now 2 days later, it does not detect the USB mic. System Pref sees the USB mic, but Audacity Pref does not. Any ideas?
matz2018
Re: USB Mic not detected
Post by matz2018 » Wed Apr 01, 2020 11:36 am
OK. It looks like I have solved this problem simply by shutting down the computer and rebooting. However, that has led me to another problem which I have to investigate. I may be back.
