Timer Record is not starting where it should in the timeline.
waxcylinder
Re: Timer Record is not starting where it should in the timeline.
Post by waxcylinder » Tue Apr 14, 2020 6:11 pm
You may be pleased to know that this bug has just been fixed - just in time for 2.4.0
I just tested it as OK on W10 and Mac - it just needs a Linux test now
https://bugzilla.audacityteam.org/show_bug.cgi?id=2382
Timer record: if a labels are present recording starts at last label position - not cursor position
Peter.
Emerogork
Post by Emerogork » Tue Apr 14, 2020 9:22 pm
Sooo cool!
I have been exploring so many finger calisthenics to see if I could somehow manipulate settings to get it to work.
Now I can get rid of that worm on my tongue...
waxcylinder
Post by waxcylinder » Fri Apr 17, 2020 11:36 am
Hi Emerogork,
you'll be glad to know we just fixed this for the (hopefully) soon to be upcoming 2.4.0 8-)
Peter.
Emerogork
Post by Emerogork » Fri Apr 17, 2020 6:33 pm
I appreciate the notification that progress has been made and would have checked out the URL but could not get through the captcha. I am so tired of dicking around with that. I fail so many times and just don't understand it...
But I do appreciate the effort that was made.
Is there a release date for the 2.4.0 version?
waxcylinder
Post by waxcylinder » Fri Apr 17, 2020 9:59 pm
It's still planned for 7th May - but it might slip a little we are dealing with a few tricky bugs that we'd like to fix
Peter.
