I downloaded and used my Software Manager to Install LAME, but when I click on Launch- Nothing happens!
Anybody have any suggestions on what to do? Thanks for your time and effort. I have Mint 19.1.
LAME won't Launch
Please state:
Please state:
Re: LAME won't Launch
LAME is now built-into Audacity (since 2.3.2) so you no longer have to install it.
