Opening Error
TJB
Opening Error
Post by TJB » Sat Mar 21, 2020 3:16 pm
Question #1: just downloaded version 2.3.3 but can't open ... I get a pop up which says " error opening recording device. Error code : 0 success". Any thoughts or ideas?
Question #2: i record podcasts for the blind so all i need is a simple program to record, correct my mistakes, overwrite the hiccup, and then upload the finished broadcast to dropbox ........ So here's my question ... Do i need to use a mixer and record thru that ........... Or can i merely plug a mic into the computer using a usb cord and then use audacity for everything???
Please bear with me as these are probably dumb questions (but sadly a reflection of the user)
Thanx, tom
Reason: Changed from all upper case.
Re: Opening Error
Post by steve » Sat Mar 21, 2020 3:41 pm
That is probably due to a Windows security setting. See: https://alphamanual.audacityteam.org/ma ... ice#W10mic
If you are only wanting to record one person at a time, then you can use a USB microphone.
Note that Audacity does not support more than one USB microphone at a time. If you want to record multiple people at the same time, then you would be better to use a mixer with conventional microphones (ideally one per person). Some mixers have built-in USB support for recording a stereo mix. Other mixers have only analog outputs, so need to be plugged into an audio interface (I use a Behringer UCA 202, which is cheap, reliable and works well with good sound quality).
TJB
Re: Opening Error
Post by TJB » Sat Mar 21, 2020 4:21 pm
Steve ...thanx for the quick reply ... did as you suggested but still get the same pop up.
Would it make any sense to ditch the recording setup I have (mixer) and just purchase a USB mic ... and would that possibly cure the issue ... and lastly, if I were to purchase an audio recording program (rather than Audacity), do you have any recs without breaking the proverbial bank???
Re: Opening Error
Post by steve » Sat Mar 21, 2020 11:05 pm
See if this video helps: https://www.youtube.com/watch?v=wYl7Vq3UDso
Whatever recording app you use, the Windows permissions need to be set correctly to fix this problem.
