Moving to new computer, Audacity doesn't record from on-line
Emerogork
Post by Emerogork » Fri Mar 13, 2020 6:21 am
I have used this program for many more years than I can remember and at my age, it isn't very far. Most of my recording is from web sites. I now have a new computer, I cannot seem to get it to record that way. I can play Audacity files with no problem.
The only record I can achieve is through the computer microphone, nothing from on-line.
In the original set up, I jumpered the line-out to the mic in. It works flawlessly. The new computer does not have a line-out. It only has the 4pin jack (Mic, Left out, Right out, ground) I played with the jumping but no luck.
I set MME/Windows D/Windows V, Primary Sound/Windows (rea, Mono/Stereo, and Speaker Head/Microsoft Sound in the four pull down menus in the top bar but nothing gets my unit to record from On-Line. (Forgive what seems to be truncated entries but that is what the computer shows me.)
Maybe this makes more sense to you than it does for me.
I am open to suggestions.
v2.3.0
Win 10
Trebor
Re: Moving to new computer, Audacity doesn't record from on-line
Post by Trebor » Fri Mar 13, 2020 9:44 am
Choosing WASAPI as the audio host is one way to record what the computer is playing ...
https ://manual.audacityteam.org/man/tutorial_selecting_your_recording_device.html
https ://manual.audacityteam.org/man/devices_preferences.html
Emerogork
Post by Emerogork » Fri Mar 13, 2020 11:18 am
Yep, been there. Tried that.
With KTOO web site playing NPR news, I get audio recording only if I have the remote amplifier volume up and Audacity records the ambient audio in the room. The burst that is shown is when I tapped near the microphone.
Trebor
Post by Trebor » Fri Mar 13, 2020 11:42 am
WASAPI only works if you select the speakers as the recording device, (& 2 channels). You have the microphone selected.
Another option is to select stereo-mix as the recording device.
As it's a new computer stereo-mix may be disabled & hidden. Here's how to make it visible, (if it's available) ...
thewindowsclub.com wrote:In Windows 10/8/7 the lesser-used devices including the WaveOutMix, MonoMix, StereoMix are disabled by default.
If your sound driver supports this feature, you can enable it. This post shows how to enable all Recording Devices and make Windows show even the disabled devices ...
https ://www .thewindowsclub.com/how-to-enable-all-recording-devices-in-windows
BTW Don't download anything from thewindowsclub.
waxcylinder
Post by waxcylinder » Fri Mar 13, 2020 1:57 pm
No so Trebor - I can set host to WASAPI and record from my PC's onboard Mic - but mostly I have it set to record loopback for internet webcasts.
Peter.
Emerogork
Post by Emerogork » Fri Mar 13, 2020 6:29 pm
I am beginning to use my microsoft vocabulary...
On my test machine, I tried to follow the recommendations listed here already. I do not see methods to get to those screens and it used to be so easy. I get to a useless screen and continue to explore. I click on a different topic, I get sent back to that useless screen. again, and again. Finally I stumble onto it, it does not have the same options but eventually find the fix and set it. I teat Audacity and it is working exactly as I want.
I did say that I was on my test machine...
The computer that needs the adjustment is in a different room and does not have e-mail so I have to start the guessing all over again. Sooner or later...
At least I now know that it can be done.
Emerogork
Post by Emerogork » Fri Mar 13, 2020 7:43 pm
Here is a new error for any of the settings I choose from the recording screen.
Trebor
Post by Trebor » Sat Mar 14, 2020 12:27 am
If you want to record the sound coming from the speakers, don't select microphone, select speakers ...
don't chose microphone if you want to record speakers.png (1.09 MiB) Viewed 212 times
this works for me.png (30.37 KiB) Viewed 209 times
Emerogork
Post by Emerogork » Sun May 03, 2020 6:48 am
I had about 6 weeks of success. After I got this one working, I tried it on my other (identical) computer but failed at every turn.
I have no idea what changed but just this morning, this computer decided to go back to some other setting and I get all the errors I have mentioned already.
The only thing that is different is that I am using WebEx to teach a computer science class and it uses the mic and camera however, for the last 3 weekends Audacity was recording flawlessly. I doubt that the on-line class did not affect anything.
Still searching...
Emerogork
Post by Emerogork » Sun May 03, 2020 7:08 am
Ok, I think I found it. Somehow the loopback (?) was disabled. It was not an option in Audacity menu.
Settings/Manage Sound Devices/Input Devices Stereo mix/ was disabled. Now the Stereo Mix menu item was visible in Audacity. Recorder is working but only on that one computer. Two others, not so much.
I hope that was the only thing I changed. At least the next time it happens, I can come back to this message and might be able to fix it.
When is 2.4.0 being released. I hope to see the Timer Record fix...
