Audacity can not load ANY aup file
Please state:
NiceMicro
Operating System: GNU/Linux other
Re: Audacity can not load ANY aup file
Post by NiceMicro » Fri Mar 06, 2020 2:06 pm
steve wrote:
Fri Mar 06, 2020 10:19 am
Look in ~/.audacity-data/.
The contents of that folder:
Code: Select all
drwxr-xr-x  5 nicemicro nicemicro  4096 márc   6 22.48 .
drwx------ 37 nicemicro nicemicro  4096 márc   6 19.48 ..
-rw-r--r--  1 nicemicro nicemicro  2612 márc   6 22.48 audacity.cfg
drwxr-xr-x  2 nicemicro nicemicro  4096 márc   4 10.17 AutoSave
drwxr-xr-x  2 nicemicro nicemicro  4096 márc   3 00.34 Macros
-rw-r--r--  1 nicemicro nicemicro 36136 márc   6 22.48 pluginregistry.cfg
drwxr-xr-x  2 nicemicro nicemicro  4096 márc   3 00.34 Plug-Ins
-rw-r--r--  1 nicemicro nicemicro   642 márc   3 00.54 pluginsettings.cfg
The subdirectories (all three) are empty. There is no autosave file.
Do you also have a folder:
Code: Select all
/var/tmp/audacity-<your-name>/
If you do, does it contain one or more folders named something like:
Code: Select all
project1190746588
This directory exists, and contains no file or directories.
NiceMicro
Post by NiceMicro » Fri Mar 06, 2020 2:27 pm
I have just installed Audacity 2.4.0-alpha-Mar 6 2020 from the AUR. The same problem still persists. So, I went back to the Audacity version in the repository.
Post by steve » Fri Mar 06, 2020 4:51 pm
The three ".cfg" files are Audacity's configuration files. Deleting these three files (while Audacity is closed) will reset Audacity to it's factory settings.
From ~/.audacity-data/ move these three files to your Desktop (or any other convenient location):
Code: Select all
audacity.cfg
pluginregistry.cfg
pluginsettings.cfg
On restarting Audacity, you should see the welcome message.
Then try saving and opening a project.
If that works, please post those three files with your reply so that we can try to figure out how this happened.
NiceMicro
Post by NiceMicro » Mon Mar 09, 2020 1:41 pm
I moved the three files somewhere else.
I opened Audacity, recorded a new project, saved it.
When I try to open it, I get the same error as before.
Post by steve » Mon Mar 09, 2020 2:02 pm
Strange.
Can you Import audio files into Audacity?
what happens if you use the "File > Open" command and select a wav file?
NiceMicro
Post by NiceMicro » Fri Mar 13, 2020 3:12 pm
Strange.
Importing audio from video files (which is what I do most often) works, opening MP3s and other audiofiles also work. I can manipulate the audio and then export it to ogg files and that works well, too.
Post by steve » Fri Mar 13, 2020 3:37 pm
What are the permisions for the directory: /home/nicemicro/Documents
Are you logged in as "nicemicro"?
NiceMicro
Post by NiceMicro » Sat Mar 14, 2020 1:01 am
Code: Select all
drwxr-xr-x  10 nicemicro nicemicro  4096 márc   9 22.36 Documents
Yes, my username is "nicemicro". Could this be a permissions issue?
Post by steve » Sat Mar 14, 2020 12:05 pm
A bit of a long shot, but I'm running out of ideas of what the problem could be. User nicemicro has read write permissions to the Documents folder (as expected), so it's not looking like a permissions problem.
In the project that you posted, the data files (.au) are present in the test_data folder, and their names match the names in the project file "test.aup". Audacity should therefore recognise the data files as belonging to the "test.aup" project. When I try to open test.aup, Audacity does recognise the data files as belonging to the project (as expected). I can't account for the fact that on your machine, Audacity does not recognise the .au files as belonging to the project.
When you get the warnings:
Code: Select all
00:18:09: Warning: Orphan block file: '/home/nicemicro/Documents/test_data/eff/d1f/eff1f37c.au'
00:18:09: Warning: Orphan block file: '/home/nicemicro/Documents/test_data/eff/d1f/eff1fc6d.au'
Do those files match the file names in the "test.aup" file? (View the "test.aup" file in a text editor).
NiceMicro
Post by NiceMicro » Sun Mar 15, 2020 8:46 am
Code: Select all
Yeah, I have checked multiple test files, and the filenames align with what's in the
Code: Select all
simpleblockfile filename="eff1ffde.au"
parts. I found that the XML file contains a comma instead of the period sign as a decimal separator (my locale is a little weird as I use US English as the language but use Hungarian date and number formatting). I manually changed the commas to periods but didn't have any effect.
Audacity used to work for me up until around 26th of February.
Now looking up the logs, the last change in Audacity was on 14th of february,
Code: Select all
[2020-02-14T22:44:02+0900] [ALPM] upgraded audacity (1:2.3.3-1 -> 1:2.3.3-2)
which is a re-compiled form of the same version based on newer dependencies, I guess. But again, Audacity still worked after that. Is there a debugging mode that could be of help?
