Updating Audacity Version 2.3.2
Help for Audacity on macOS.
brbrown
Post by brbrown » Mon Mar 02, 2020 9:52 am
I have a MacOSX Catalina 10.15.3 with Audacity 2.3.2. I am confused with some of the posts about updating. All I wish to know is, do I need to uninstall version 2.3.2 before installing version 2.3.3 or does the later version just update the new version please?
brbrown
Re: Updating Audacity Version 2.3.2
Post by brbrown » Mon Mar 02, 2020 2:54 pm
Problem solved. I uninstalled 2.3.2 and then installed 2.3.3 afterwards.
swami7774
Post by swami7774 » Wed Mar 04, 2020 1:37 am
Are you able to record from your computer using Audacity 2.3.3 without Soundflower or some similar add-on? That's been the big problem with Catalina.
brbrown
Post by brbrown » Wed Mar 04, 2020 9:41 am
Hello Swam, I haven't tried since updating. I'll post again when I have.
