Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Post
by kozikowski » Mon Mar 09, 2020 5:13 pm
I play the track and then sing while it's playing... Makes sense?
No it doesn't. How are you playing the track? If you're trying to do both of those jobs in Audacity, you can get track doubling which will boost the track volume and can give you the overload sound damage you have.
Cyath
Post
by Cyath » Tue Mar 10, 2020 4:51 am
I generally just move my face back from my mic. Problem solved.
So you're telling me I need to or do not need to overdub? I am confused.
Post
by kozikowski » Tue Mar 10, 2020 5:11 pm
If you have a way to solve the problem, then you're good.
Cyath
Post
by Cyath » Wed Mar 11, 2020 1:17 pm
I would like to know if compression does anything about it though. More knowledge is good!
