Help for Audacity on macOS.
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
fburg
- Operating System: macOS 10.14 Mojave
Post
by fburg » Mon Feb 17, 2020 9:55 am
Which model?
Rode-NT USB
Most Rode mics have very good SNR (signal to noise ratio).
Not finding any problems with the Rode SNR - it was my Samson C01U which had the hiss problem
- Site Admin
Post
by steve » Mon Feb 17, 2020 10:46 am
The NT1-A USB has a "presence boost" in the range 2 to 10 kHz, rising to around +7 dB in the 5 to 6 Hz range.
This does not suit all voices and may overemphasize sibilance.
That presence boost may be countered by applying Equalization to reduce that range.
- ny1a-usb.png (67.15 KiB) Viewed 118 times
- graphic.png (18.09 KiB) Viewed 118 times
fburg
Post
by fburg » Mon Feb 17, 2020 9:10 pm
That's very interesting. Will give it a go - thanks!
