I found a permanent solution to the Mac Catalina and Audacity not recording issue.
I know there is already the work around involving the code with terminal. However, I took it one step further.
https://www.youtube.com/watch?v=sFUOKU6AZ8Q
Audacity Catalina Fixed!!
Jagilsdorf
