Export issue using multiple tracks
Please state:
phippsy
Post by phippsy » Tue Feb 04, 2020 4:52 pm
Hi,
* Using Ubuntu 18.04
* Using Audacity version Audacity 2.2.1
* Installed through PPA, apt-get program
My issue is to do with Exporting Multiple WAV files, I have a 4 channel track that has been labelled with one label track and I have been able to go though the exporting process but it yields 2 channel WAV files.
Does anyone know if I'm going wrong.
