Audacity Version 2.3.3.
Mic Used: Jabra Evolve 65 Bluetooth Headset
Op System: Windows 10 on HP
My first recording went great! No issues. I was able to record, edit and publish with ease.
With the same equipment, I recorded my second project and saved it. Later, I reopened the project and there are multiple instances (2-10 seconds) where there is a long beep/buzz sound that took over the pre-recorded audio.
Any thoughts on this?
Long Beep Overwrote my Recorded Audio
