How to keep original date and time of imported files after exporting in Audacity...?
Boi Social
Post by Boi Social » Wed Jan 29, 2020 4:51 pm
Hi,
I've been searching the forum to find an answer to my question first, BUT no succes...
I make alot of voice memos that I need to sort chronologically and now i just need to keep numbering them. Which is really tedious work :S
Is there ANY WAY to keep the date created and date modified information from my IMPORTED audio files, AFTER batch exporting them?
Greets,
Boi
Darcon64
Re: How to keep original date and time of imported files after export...?
Post by Darcon64 » Wed Jan 29, 2020 5:08 pm
I had this problem with video files from an SD card.
My solution was: DO NOT COPY the files from the card to your desired harddrive. Instead, select the "Send to" option. (You find this when you right click the relevant file.) Now select the desired drive. It will only send to the root directory. You can then move them from the root directory to the desired folder.
In the desired folder (see attachment), you should see a tab "Date Created". If you can't see it, where it says "Name", right click will bring up a menu. Scroll down and select the desired option (Date Created) and hopefully this will solve your problem.
Audacity question.png (6.8 KiB) Viewed 538 times
Boi Social
Post by Boi Social » Wed Jan 29, 2020 5:34 pm
Sorry what?
I have NO problems transferring my files to my computer...
I want to know how to have AUDACITY KEEP the dates in the files after editing them with whatever effects or cuts i've done in post...
Not sure if it's me that is confused here, or if it's you :S
Re: How to keep original date and time of imported files after exporting in Audacity...?
Post by steve » Wed Jan 29, 2020 6:37 pm
No.
When you export from Audacity, it creates a NEW file (even if you overwrite the original file, you are overwriting it with a new audio file).
Probably the easiest solution would be to include the date / time in the file name. For example, rather than exporting as:
"my-file.wav"
export it as:
"my-file_2020-01-29_18-33.wav" (33 minutes past 6pm, 29th January 2020)
Your (new) exported files can then be easily sorted by name.
IMPORTANT: Don't use "special" characters in the file name. Definitely do not use the "\" (backslash) character.
snapshot2020
Post by snapshot2020 » Thu Jan 30, 2020 1:21 am
Thank you Darcon64 very helpful information.
Boi Social
Post by Boi Social » Thu Jan 30, 2020 8:11 am
No.
Wouldn't it be possible to implement this in a future update? Or are there any other software out there that allow this??
"my-file.wav"
export it as:
This is essentially what I'm already doing right now, so it kinda beats the purpose of this topic hehehe
Post by steve » Thu Jan 30, 2020 10:46 am
Audacity does not operate directly on audio files - On import, the audio is copied from the audio file into the Audacity project. This is a core design feature of Audacity and of the Audacity project format.
There are some apps that can perform simple edits directly into an audio file (in situ without creating a new file) but they are limited to simple editing and metadata changes. Example: mp3DirectCut (https://en.wikipedia.org/wiki/Mp3DirectCut)
Boi Social
Post by Boi Social » Fri Jan 31, 2020 7:30 pm
But isn't it possible to also import the metadata into audacity??
Post by steve » Fri Jan 31, 2020 8:41 pm
"Metadata" in audio files is a different thing from the Windows time stamp (file creation / modification time).
Yes Audacity does support metadata in files, though it does not support every metadata option for every audio file type, only the common tags. More info here: https://manual.audacityteam.org/man/met ... ditor.html
