[SOLVED] Unable to find specific Nyquist plug-in
jh90s
Post by jh90s » Tue Jan 28, 2020 6:37 pm
I used to have a Nyquist plug-in which would take 2 tracks and apply the volume / characteristics and peaks of one track to the other. I can't find it anywhere now! It was on the forum I think, and it was posted by "steve".
Any ideas?
Re: Unable to find specific Nyquist plug-in
Post by steve » Tue Jan 28, 2020 7:19 pm
I'm guessing that you are referring to my "Dynamic Mirror" effect: viewtopic.php?p=335940#p335940
Up to date instructions for installing Nyquist plug-ins (Windows): https://manual.audacityteam.org/man/ins ... st_install
jh90s
Post by jh90s » Tue Jan 28, 2020 8:12 pm
That's the one! Thanks!
