Can't record from cassette. HELP
Help for Audacity on macOS.
neilr1
Operating System: OS X 10.6 Snow Leopard or earlier
Post by neilr1 » Wed Jan 22, 2020 2:26 am
I have everything set up properly and the cassette deck is seen in the Apple preference. I click on the cassette for audio in and still it hears the mic. The problem is that the only sound that is recorded is my voice obviouly coming in from the computers mic. . I have not been able to get Audacity 2.1.3 (whih came with the WIKOO tape deck to pick up the audio from the tape. Very very frustrating. Help would be appreciated so I don't have to return the cassette player and find somewhere else to do this. Thanks in advance. using High Sierra 10.13.6
Neil
waxcylinder
Re: Can't record from cassette. HELP
Post by waxcylinder » Wed Jan 22, 2020 10:07 am
For a start I'd upgrade to the latest Audacity which is now 2.3.3 - you can get it from our Website: https://www.audacityteam.org/download/mac/
I'm assuming this is a USB device - in which case make sure it's plugged in before you start Audacity - you will the need to select the USB device as the input on the Audacity Device toolbar - and your Mac's onboard speakers as the output.
See this set of Tutorials in the Audacity Manual: https://manual.audacityteam.org/man/tut ... to_cd.html
especially this one: https://manual.audacityteam.org/man/rec ... ables.html
neilr1
Post by neilr1 » Thu Jan 23, 2020 11:55 pm
Sadly, I done everything you suggested and followed every manual and tutorial and still am not able to get the Wikoo uSB device to be seen by the prgram. After too many hours of trying I am going to return the device and dump the program. Most sadly is that you do not have any telephone support that might have helped me make this work. I am a university college professor in computer science so I do not think it is because I could not follow directions. I have even changed the cable out for several others.
Well, off to pay a company to do the transference,
neilr1
Post by neilr1 » Fri Jan 24, 2020 12:05 am
Well, i finally got the program to see the deck and moments after it begins to record the program crashes. Sorry I have wasted so myuch of my time.
Post by steve » Fri Jan 24, 2020 9:26 am
Those cheap Chinese USB cassette players are bad for Audacity's reputation. Lots of people have problems with them, and because they often include a copy of Audacity (usually an out of date version), people often blame the software (unless they try using other software and get the same problems).
Audacity is a free program, made, documented and supported by volunteers. Do you think it's reasonable to expect a volunteer to give our their personal phone number so that they can be called all hours of the day and night by people wanting technical support? Even commercial programs rarely provide telephone support unless you pay a lot of money each year (typically around $5000 pa) for that level of support.
waxcylinder
Post by waxcylinder » Fri Jan 24, 2020 3:03 pm
When I transcribed my tape cassettes I did not use a cheapy Walkman size device - instead I used my Nakamich-BX2 on which all my recordings had been made originally - and before I started the transcription task I had the deck professionally serviced by Bowers&Wilkins in Worthing (UK Nak agents).
The deck was connected to my PC's USB port via an external USB soundcard (Edirol UA-1EX - other makes are available.)
I always used the latest version of Audacity.
The results I got from this setup were excellent - certainly hi-fi quality - and I listed on QUAD kit with QUAD ESF-57 electrostatic speakers.
If you do not already have a decent cassette deck - then there are several available on the market from reputable makes that have suitable USB outputs - for example Tascam, TEAC, Marantz etc. This would probably be cheaper than turning the job over to hired-help ...
Sliphorn
Post by Sliphorn » Fri Jan 22, 2021 8:50 pm
I updated to the latest version but still cannot figure out what is wrong. I am attempting to paste in a screen shot to show what it looks like. I am not sure if it went or not.
Audacity Issue.png (156.21 KiB) Viewed 355 times
billw58
Post by billw58 » Fri Jan 22, 2021 10:59 pm
As Steve said, those cheap cassette-to-USB devices are bad - not just for Audacity's reputation, but pretty much unusable on Mac.
Try this.
Go to Apple menu > System Preferences > Sound > Input
Plug in the cassette via USB and see if it shows up in the Input list (USB PnP Audio Device)
If it does, start playing a cassette.
My guess is that you will see the same behaviour you see in Audacity. That is, the devices disconnects after a few seconds. This demonstrates that is not a problem with Audacity, but with the device.
-- Bill
jademan
Forum Crew
Post by jademan » Sat Jan 23, 2021 1:46 am
A very large number of people are reporting problems On Mac with these Super USB Cassette Capture devices. I think they are made to operate off of USB power, which I am thinking could be a large power drain. Has anyone ever tried putting in batteries to assist the power situation?
billw58
Post by billw58 » Sat Jan 23, 2021 3:49 pm
It is my understanding that those devices require 1 or 2 AA batteries and will not run without them.
-- Bill
