Split Points, Labels, and "Snap To"
Would you consider making the label track adhere to the settings for "Snap To"? If I have Snap To enabled and I manually move a split point, I expect it to realign according to my Snap To setting. Thanks.
Re: Split Points, Labels, and "Snap To"
I can see how this may be useful on occasion, but personally I find it easy enough to just delete a label and create a new one, rather than moving the label.
