Crash during recording
Help for Audacity on macOS.
rushots
Operating System: macOS 10.12 Sierra
Post by rushots » Sat Jan 04, 2020 11:45 am
Audicity 2.3.3 on Mac OS X 10.12.6 Sierra on iMac (21.5-inch, Mid 2011, iMac12,1) Processor: 2.5 GHz Intel Core i5; Memory: 4GB; Graphics: AMD Radeon HD 6750M 512 MB
Hard Drive: Mac OS Extended (Journaled), Capacity: 499.23 GB, Available: 438.23 GB
I am recording from line-in. After about an hour Audacity crashes with error:
Internal Error
Internal error at Project.cpp line 156.
Please inform the Audacity team at https://forum.audacityteam.org/.
I have plenty of hard drive space. This error just started cropping up. It won't let me save even the hour's recording most of the time. I have successfully recorded for 12+ hours in the last month with the same equipment and configuration. At one point recently I did try to save a project, but I erased that data and quit trying that. I have Audacity set to 32 KHz sample rate Mono.
I'm not sure what other information is relevant.
