Date/Time Metadata for Recovered Audacity Projects
LynneL
Operating System: Windows 7
Post by LynneL » Sat Dec 28, 2019 11:46 pm
Hi, if audacity crashes when multiple windows are being used and is reopened at a later date, I'm wondering if there is some quick way to determine the date/time metadata associated with each recovered project. In the AppData/Local/Audacity/SessionData folder, the "date modified" information is present, but I'm having a hard time linking each folder's respective information to the correct audacity project when multiple are recovered. i.e. there's nothing I can see in any of the windows that says, e.g., "this project is from the 'project27193' folder". Is there any way to quickly find this information for each recovered project?
For reference the computer I'm on at the moment is using Windows 7 and audacity 2.3.0.
