Weird:
I've been using the SHIFT + R command to record forever. This afternoon, I opened up Audacity, a screen popped up about some "keyboard command keys", I pushed okay or cancel or whatever and now I lost my ability to record via SHIFT + R... I now have to go up to "Transport" and select Record New Track... I can still do several other SHIFT + commands...
Can someone help me restore the SHIFT + R command??
Many Thanks,
-T
LOST my SHIFT + R command to record...???
Re: LOST my CTRL + R command to record...???
The default is ...
SHIFT + R = record
CTRL + R = repeat last effect
https ://manual.audacityteam.org/man/keyboard_preferences.html
My apologies... I MEANT SHIFT +R...Trebor wrote: ↑Thu Dec 19, 2019 10:00 pm
The default is ...
SHIFT + R = record
My SHIFT + R command has somehow become disabled and I am trying to restore that function...
Thanks,
-T
There is a button in Audacity preferences to reset all the shortcut keys to their default-settings ...
I've never had need to use it myself though.
"keyboard command keys" is a Microsoft thing, not Audacity.
Re: LOST my SHIFT + R command to record...???
You are the GOAT... Worked like a charm!
Thank you!
There was an option to reset to "Standard" or "Full". I chose "Standard"...
Could you possibly tell me what the difference is between "Standard" and "Full"?
As long as I can record I'm good, but I suppose it would be good to know...
Thanks!
-T
Thank you!
Thanks!
-T
waxcylinder
Please see this page in the audacity Manual: https://manual.audacityteam.org/man/key ... rence.html
