Weird Audio Stutter
Help for Audacity on macOS.
jazkeys
Weird Audio Stutter
Post by jazkeys » Fri Dec 13, 2019 8:25 pm
Hi!
I just imported a stereo file into a new Audacity session, but while the file plays seamlessly when previewing from the Finder, it is stuttering really badly when playing within Audacity. I just did another project using the same setup with no such problems. I am using an iMac running 10.12.6 (Sierra), recently installed the most recent Audacity build (2.3.3.0) and downloaded and installed the indicated ffmpeg libraries, and would appreciate any tips on how to fix it (I might have older versions of both Audacity and the ffmpeg libraries, so any specific tips regarding files to definitely delete if they might be causing this would be greatly appreciated).
Thanks!
