"EXPORT THE SELECTED AUDIO"
Blueflame
Post by Blueflame » Fri Dec 13, 2019 10:57 am
I can't see why the "EXPORT THE SELECTED AUDIO" as been removed
it makes it a lot harder to split to a recording into a number of parts
Blueflame
Re: "EXPORT THE SELECTED AUDIO"
Post by kozikowski » Fri Dec 13, 2019 11:40 am
Screen Shot 2019-12-13 at 3.38.45.png (105.48 KiB) Viewed 360 times
Post by steve » Fri Dec 13, 2019 11:42 am
"File menu > Export > Export Selected Audio..."
Blueflame
Post by Blueflame » Sat Dec 14, 2019 3:01 pm
Thank you both
Blueflame
