Remove sharp click tone with audacity
slavik
Post by slavik » Fri Dec 13, 2019 4:59 am
Dear co-authors,
I edited my single titled Girl from the North using audacity.
During the saxophone solo there is clearly a sharp click audible, a mistake by the music studio manager. Is it possible to remove this with audacity?
Is it also possible to lower very high sound tones that sound too sharp?
Thanks in advance.
grtz,
Gilbert ;)
Meisje uit het Noorden-0000.jpg (15.25 KiB) Viewed 220 times
Trebor
Re: Remove sharp click tone with audacity
Post by Trebor » Fri Dec 13, 2019 6:54 am
See ... https ://manual.audacityteam.org/man/click_removal_using_the_spectrogram_view.html
You only attached a jpeg image, (the artwork), not a sound-file.
DVDdoug
Forum Crew
Post by DVDdoug » Fri Dec 13, 2019 6:15 pm
Do you mean musically-sharp with the pitch too high?
Or just "harsh", with the high frequencies too strong/loud?
The Equalizer can be used to adjust the volume of selected frequency bands. The high frequencies are on the right and low frequencies on the left. (For "experimenting", I recommend the Graphic EQ mode.)
...Pitch correction of selected notes is more complicated.
