Scarlett 2i2 on windows 10 - not recording
raddy59
Post by raddy59 » Fri Dec 06, 2019 2:45 pm
Attaching an audio line form a Yamaha Reflex, through Scarlett 2i2.
Error message:
"Error opening sound device"
I have toggled my settings, finally I have, rescanned, toggled overdub, software playthrough, searched thsi forum
MME Focusrite Mic. Mono Focusrite speaker
I just cant sort this out
Works fine in Ableton
raddy59
Re: Scarlett 2i2 on windows 10 - not recording
Post by raddy59 » Fri Dec 06, 2019 3:39 pm
I had this problems a few days now - asked the question a few days ago then delted it thinking the lack of response meant it was a stoopid question
Anyhow just found this
https://www.youtube.com/watch?v=23q362dL9GY
Lousy vid but fixed the problem
Post by steve » Fri Dec 06, 2019 3:44 pm
Ooh, gives me a headache to watch that :D
It seems to be basically the same as what is written in this post (pinned to the top of the Windows forum board): viewtopic.php?f=46&t=100117
Brendan1956
Post by Brendan1956 » Tue Jan 21, 2020 9:01 pm
I tried this but my settings were already ok.
My problem is that audacity was fine for several weeks and recording well off youtube with no problems. Then all of a sudden when I record I get only flat lines like it is not picking up any sound from my Lenovo X1 laptop.
I am using windows. Anyone any suggestions or fixes please?
Post by steve » Tue Jan 21, 2020 9:45 pm
The "WASAPI loopback" method is usually reliable: https://manual.audacityteam.org/man/tut ... ndows.html
