Latest, most up-to-date instructions needed.
Help for Audacity on macOS.
swami7774
Post by swami7774 » Fri Dec 06, 2019 2:07 pm
The work-throughs to record audio on Audacity don't work. I've done the Soundflowerbed/sound prefs/terminal bits and none works reliably. I was able to get it all working once, last weekend, but not since. Is anything in the pipeline to permanently and easily fix this?
Re: Latest, most up-to-date instructions needed.
Post by steve » Fri Dec 06, 2019 2:31 pm
It works for me with Audacity 2.3.2 on Catalina 10.15.1. I've not tried Audacity 2.3.3 yet (Catalina just finished updating 5 mins ago).
I've not tested yet, but I don't expect Soundflowerbed to work as it is obsolete.
Audacity 2.4.0 is due to be released fairly early 2020, which should fix the Catalina issues for Audacity.
We have no association with the makers of Soundflower.
Post by steve » Fri Dec 06, 2019 2:43 pm
I've tried it now.
When I first tried launching Audacity, I got a message saying that Audacity could not be opened because the author could not be verified.
To fix that,
  1. I used "control + click" on the icon in the dock, and then selected "open".
  2. When prompted, I confirmed that I wanted to run Audacity
  3. Then I quit Audacity
After doing that, the terminal command to run Audacity now works.
swami7774
Post by swami7774 » Fri Dec 06, 2019 4:02 pm
Thank you. Does Audacity 2.3.3 have any 32/64 bit problems?
Post by steve » Fri Dec 06, 2019 4:23 pm
Audacity 2.3.3 is a 64-bit app. It requires a 64-bit version of macOS.
swami7774
Post by swami7774 » Fri Dec 06, 2019 4:37 pm
Thanks. Pretty sure Catalina is 64-bit. Mac made a big thing out of letting users know certain apps wouldn’t work without upgrading from 32. At this point I may wait for the new Audacity due out soon(hopefully). Doing otherwise is not worth the aggravation.
waxcylinder
Post by waxcylinder » Sun Dec 08, 2019 5:51 pm
Catalina is certainly 64-bit
Post by kozikowski » Sun Dec 08, 2019 9:16 pm
Maybe not quite enough words. MacOS has been 64 bit for a long time.
That's 10.9.5.
Catalina's trick is it's only 64-bit. Under those conditions, as an example, my off-air "TV Set" will stop working. That's one tiny example why I'm not breaking down the door to upgrade.
swami7774
Post by swami7774 » Sun Dec 08, 2019 9:30 pm
Gotcha. It’s a little late for those of us who have upgraded already.
Post by kozikowski » Sun Dec 08, 2019 9:33 pm
In other words, all of them likely to be useful. "Frances" is an 11 year old Mac and has 64-bit compatible architecture. I should try the install later.
