Music list format
Blueflame
Music list format
Post by Blueflame » Tue Dec 03, 2019 3:43 pm
I have just edited some music off tape with Audacity and in the program the layout was like this
Xxxxxx – Xxxx Xxxxxx Xxxx But when I looked at it in Windows Explorer I got Xxxxxx – Xxxx
What Have I done wrong it has worked OK
Blueflame
DVDdoug
Forum Crew
Re: Music list format
Post by DVDdoug » Tue Dec 03, 2019 4:39 pm
in the program the layout was like this Xxxxxx – Xxxx Xxxxxx Xxxx But when I looked at it in Windows Explorer I got Xxxxxx – Xxxx
Sorry, I don't understand what you're talking about.
Windows will generally show the file name and some of the metadata. Audacity has a metadata editor or you can use a 3rd-party tool like MP3tag.
Blueflame
Post by Blueflame » Tue Dec 03, 2019 5:16 pm
In Audacity I get Name -- Title -- Contributing artists etc
in file explorer I get only Name then date
It as worked before, both formats were the same
So what have I done wrong
Blueflame
DVDdoug
Forum Crew
Post by DVDdoug » Tue Dec 03, 2019 7:02 pm
OK. What format are your files? Different formats use different tagging (metadata) standards
MP3 use ID3 tags and there are two versions of ID3 and other formats use other standards. Audacity doesn't fully-support all of them and I don't know if Windows Explorer supports them all.
You may need a 3rd-party utility like MP3tag. (MP3tag can handle most formats, it's not just for MP3s, but it can't tag WAV files.) Or, your audio player software may be able to display & edit the tags.
Blueflame
Post by Blueflame » Wed Dec 04, 2019 9:23 am
The files were saved it WAV
if I look at other items I have in Windows Explorer, they saved the same as Audacity's format.
It is just the last bit of editing, it is not in Audacity's format
Thanks Blueflame
Blueflame
Post by Blueflame » Wed Dec 04, 2019 12:15 pm
I have found a cure, but I do no know what coursed it
The files that had not got the Audacity Format Name -- Title -- Contributing artists etc
I transferred a file into another folder, which had the Audacity Format Name -- Title -- Contributing artists etc
Guess what the Audacity Format Name -- Title -- Contributing artists etc appeared on all files
WHY Blueflame
