I`ve had this problem before but it seemed to fix itself.
Any suggestions ?
If your system is set for Overdubbing, then both Record and Playback systems have to be working perfectly. If you're missing either one, you will get an error message.an error message that says Error opening recording device
You're a candidate for a student or even professional for hire to help you. We can continue to troubleshoot through the forum, but if you have forever changing problems, this might take a while.Now it`s doing something new.
