File Error -- Failed to read from a file
Help for Audacity on macOS.
riverbees
Post by riverbees » Tue Nov 19, 2019 5:04 pm
I have Catalina 10.5.1 and Audacity 2.3.2. Also installed ffmpeg and lame after seeing the log file looking for those files.
I was trying to removed noise from a track that was recorded using Audacity and after a few seconds, the noise reduction looks like it is working then it shows me the sad message:
Screen Shot 2019-11-19 at 11.58.39 AM.png (170.92 KiB) Viewed 237 times
I also noticed that there is a file called NoOverwritePromptqDfl5E in the Audacity Projects folder.
I was reluctant to chmod on the Audacity Folder until receiving further instructions.
Thanks for your help!
