Plug ins not working
Help for Audacity on macOS.
Rowan Triffitt
Operating System: macOS 10.14 Mojave
Post by Rowan Triffitt » Mon Nov 18, 2019 8:15 pm
Audacity 2.3.2 / Mojave 10.14.5
Help please! I use the W1 limiter plug in and have a new MacBook Air. I've installed Audacity and the plug in, enabled it in the effects tab however it doesn't load properly. I've tried a few things but no joy. See image.
Any suggestions would be much welcomed! I have also tried another similar plug in and the same thing happens.
