X-Wing fighter radio vocal effect?
Rickenbacker
Post by Rickenbacker » Mon Nov 18, 2019 2:50 am
Win 10
Aud. 2.3.2
I'm looking to reproduce that warbly, distorted radio sound you hear when the X-Wing fighter pilots speak on their radios.
That doable with Audacity?
#starwars
Re: X-Wing fighter radio vocal effect?
Post by steve » Mon Nov 18, 2019 12:42 pm
It's a long time since I've seen StarWars, but the usual approach for creating a "walkie-talkie" type effect is:
1) Apply some distortion (For example, the "Leveller" distortion https://manual.audacityteam.org/man/distortion.html)
2) Apply a "band pass filter" (For example, the "walkie-talkie preset https://manual.audacityteam.org/man/equalization.html)
Trebor
Post by Trebor » Mon Nov 18, 2019 4:30 pm
viewtopic.php?p=362567#p362567
Rickenbacker
Post by Rickenbacker » Tue Nov 19, 2019 12:37 am
I got lost after following the link & clicking on the download.
Rickenbacker
Post by Rickenbacker » Tue Nov 19, 2019 12:51 am
This is EXACTLY what I'm shooting for!
https://www.youtube.com/watch?v=_Ad84BMo_gQ
Trebor
Post by Trebor » Tue Nov 19, 2019 1:58 am
Copy & paste the code into Nyquist prompt ...
X-fighter-ish code in Audcaity's Nyquist Prompt.png (15.96 KiB) Viewed 445 times
Then apply Nyquist prompt like any other Audacity effect.
Then you have to apply a phone/walkie-talkie/ radio effect,
(i.e. 200Hz-4000Hz bandpass with hard compression).
Then you'll need to perfect an Australian accent :)
Rickenbacker
Post by Rickenbacker » Tue Nov 19, 2019 2:21 am
Argg! Tried that (with both codes) & just got a message- "Nyquist returned nil audio"
Trebor
Post by Trebor » Tue Nov 19, 2019 4:11 am
I think that translates as: you didn't select the audio you wish the code to be applied to ...
https://manual.audacityteam.org/man/aud ... ction.html
Rickenbacker
Post by Rickenbacker » Tue Nov 19, 2019 9:04 pm
Womp wooomp! Thanks! :)
