Audacity 2.3.2 / Catalina PLAYBACK problem
Help for Audacity on macOS.
jonwithoutanh
Re: Audacity 2.3.2 / Catalina PLAYBACK problem
Post by jonwithoutanh » Sat Oct 10, 2020 10:30 pm
I continued having this issue all the way up to Audacity 2.4.2. I was able to finally resolve it by removing several .component and .vst files from the various audio plug-in directories:
  • /Library/Audio/Plug-Ins
  • /Library/Audio/Components
  • ~/Library/Audio/Plug-Ins
  • ~/Library/Audio/Components
I didn't go to the effort of figuring out exactly which ones were problematic.
Solublepeter
Post by Solublepeter » Tue Oct 27, 2020 11:18 am
Did anyone manage to solve this?
I have the same error message, and the same symptom that the diagnostic panel shows no available playback rates.
(I tried renaming my plugin directory, so Audacity didn't see it) but that didn't help.)
Catalina 10.15.6
dergundel
Post by dergundel » Mon Feb 01, 2021 9:03 pm
Hi, I would like to join this topic, moving here from another one.
So months later it seems this issue hasn't been solved. I also got this list of failed AU validations after upgrading to Catalina, trying the 'terminal way'. But by no means am I getting anywhere near to the point to be able to grant permissions to the microphone (and thereby to any audio device).
MacOS 10.15.7 Audacity 2.4.2.
Any new findings out there?
jademan
Forum Crew
Post by jademan » Tue Feb 02, 2021 10:38 pm
Windows guy here. I see you are already on 2.4.2. Did you try the suggestions posted by jonwithoutanh?
I ask this because did a little google searching on this error and came up with this link that offered a similar solutions to the issue: https://mixxx.discourse.group/t/macos-c ... rs/18514/7
I hope this helps. :D
dergundel
Post by dergundel » Wed Feb 03, 2021 8:22 am
No, actually I didn't. I don't want to run into any issues moving AUs because Logic and ProTools are my main DAWs and these are working fine. And well, as a workaround I am able run Audacity on my Parallels Desktop Windows system.
