My setup consists of a new AT2020 condenser microphone hooked to the Focusrite Scarlett 2i2 3rd Gen with a 15 foot Livewire Advantage XLR cable. I'm running Audacity 2.3.2 on Windows 10, and have decent AKG earbuds plugged into the interface through a mini jack adapter. Phantom power is turned on, I'm using line, input/output is all connected.
The Focusrite Control shows the microphone is working at the right levels, and I am able to import an mp3 file into audacity with normal playback volumes. I can control the volume coming from my headphones with the interface, and I can hear myself perfectly when I speak into the mic, even as I am recording. But once I click that playback button it is barely audible and the track will barely register anything, to the point where I first thought it was not recording at all.
I have tried....
turning on the boost input +20 dB,
disabling HP noise cancellation,
changing the volume of all playback and recording device in audio control,
recording with more gain,
changed the recording and playback volume in audacity,
plugging and unpluggling,
turning phantom power on and off,
redownloading audacity 2.3.2,
making sure my computer was set to record stereo,
going to communications on Microsoft control panel and changing to "do nothing",
and checking the audio interface's properties in both playback and recording sections of the Microsoft control panel
I've spent around two days and NOTHING has helped. Using the normalizing effect in Audacity seems to be the only possible thing to help the situation, but it's far from ideal. I need to record vocals, instruments, import tracks, and edit. Any help is appreciated, I don't know what else to do!!!
